Trying to run upgrade for settlers and and run into an error message. downloads Ok but will not run. Can you help ? Direct download from "static3.cdn.ubi". . . . has same error. Game runs but upgrade file won't.
Trying to get update information to C:\Users\DANA&L~1\AppData\Local\Temp\ubiEFAF.tmp.
Found update (Patch, all, all).
Found existing file for target, attempting resume(C:\Users\DANA&L~1\AppData\Local\Temp\ubiF404.tmp.exe, (Patch, all, all))
Trying to download update file from http://static3.cdn.ubi.com/settlers_6/settlers_6_v1.7.1.exe. Destination: C:\Users\DANA&L~1\AppData\Local\Temp\ubiF404.tmp.exe.
Successfully downloaded update file.
Verifying downloaded file's CRC: 235b3ba5. Expected: 235b3ba5.
Starting update file (C:\Users\DANA&L~1\AppData\Local\Temp\ubiF404.tmp.exe)
Failed to start downloaded update file. File corrupted? (C:\Users\DANA&L~1\AppData\Local\Temp\ubiF404.tmp.exe)
I had this issue as well. Download the patch directly from the website, and run it locally. Afterwards the updater won't find a newer patch, and goes directly to the game. I don't know whether this will break again once a new patch is released, but you should be able to manually install it again at that time. Patches can be found at http://www.ubi.com/US/default.aspx under support --> patches.
This link may take you directly to the right place.
http://www.ubi.com/US/Games/Info.aspx?pId=5923&tab=download&dcId=63
