20 Most Recent
D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Questions & Answers
Dear Sir/Madam
Configure your network with an administers pass word and other computers won't be able to access.
I have a wireless router and my broadband provider
May be simply out of its signal range blocked by the building construction such as brick walls. WiFi uses wireless radio transmission, so is restricted to how much it it can send and receive like a normal radio. Obstructions absorb the power over greater distance, therefore you may need to relocate the device closer to where you need the signal to be strong
We have a wireless dlink router and cant seem to
Sounds like your WiFi router has gone back to factory defaults. There may be a button on the front of the WiFi unit that when pressed allows for a short period of time for your ps4 console and other devices to pair with it by selecting on those devices the same setting. This will allow the devices to work correctly.
I have D-link router hooked
Take away your son's netbook.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
How do i aply a security code for my router thats
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Status light not blinking on DLink router. is it
Sounds like electronics not working.Try The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Need to activate WEP,WPAOR WPA2
using your web browser log in to the router if u cant loin wirelesly use lan cable acess the router using its ip address go to wireless tab the to security tab and then activate whic ever level of security u want , good luck
How to create wireless bridge
DD WRT is a firmware upgrade sight you can find wonderful firmware upgrades that make your router come to life and Evan worth more than you payed for your original router, check the router database and see if your router is listed and capable for an upgrade to dd wrt, i did it with my dir615 and it gave me a whole host of additional optins for configurations , it was a long search for "dd wrt" but well worth it.
