SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
SOURCE: Code to enter on remote
I have the same problem with the Sony SBD-s360 blue ray and the Verizon Fios remote. Not codes work and I tried over 1000 search codes with no luck. Verizon needs to replace the remote with a later model
SOURCE: LG CE 0168 phone security code
تليفون ال جى ce0168 ومش عارف افتحه ونسيت الباسورد
SOURCE: I need code for Vizio VSB200 Sound Using Directv
I'm sorry to tell you but your sound bar isn't supported by your Directv remote - at least not officially. Your only remaining option is to perform a code scan (as explained in the manual), maybe another set of codes will match for the basic commands: on/ff and volume up/down.
