20 Most Recent
Sony XAV-7W 7 in. Car Monitor Questions & Answers
Sony dvd monitor xav-77 serial#0104414
I don't know if it will work for the 77 but I have a 70 and the master code is 5415 but only works with remote.. With remote press enter then 5415 then enter
Reset code for sony xav-62bt
Try entering code "5415" with your remote to unlock this radio.Or you can reset your
unit by reset button. download XAV-62BT manual from here and refer to
the Page 14 for reset instructions and Page 10 for reset button location
on unit. http://www.docs.sony.com/release/XAV60_EN_FR_ES.pdf
Monitor won't open or close
THE SMALL ELECTRICAL MOTOR THAT CONTROLS THIS FUNCTION IS MALFUNCTIONING. TRY TO RESET THE UNIT. IF THE UNIT HAS BEEN PREVIOUSLY RESET U MAY HAVE TO REPROGRAM THE UNIT TO CLOSE WITH KEY OFF.
Sony DVD Player Problem
By changing your battery you reset the DVD player and locked it out. It now wants the code to restart.
Here is a link to the owners manual:
http://esupport.sony.com/perl/model-documents.pl?mdl=XAV7W
I hope this helps,
Shuttle83
I need my moniter fixed
I just listed one of these on Ebay. It had the faceplate stolen but I have everything else, including the installation instructions and user's manual. Starting bid is $9.99
Rear speakers dont play with connection box
I believe this is a wiring incompatibility problem. The reason I say this is because when the mp3 player is out the jack which contains switches engages the front L&R and the Rear L&R, when the plug is inserted into the jack the jack switches should remove the audio input to the amplifier and replace it with the audio from the mp3 player. The switches should then send sound to the front L&R and the Rear L&R but the only change should be that the mp3 player is switched in instead of the audio from the raido unit. what is happening is that the jack switches are only switching in the front L&R speakers. This just might be a function of the unit. check the owners manual.
here is a site that has the manual:
http://www.docs.sony.com/release/XAV7W.PDF
