SOURCE: 1 chirp every 30 seconds
it is not the battery problem, you need to get a replacement.
the circuite board is bad.
SOURCE: I have a KIDDE /
Normally, that means the battery(s) need changing.. But, hundreds people have had problems with this combo detector, it's hard to predict what it is.
But, as I said earlier, "Normally that means the battery(s) need changing." The keyword here is "Normally".
Good luck. I hope that solves your problem.
SOURCE: alarm keeps going off constantly
Sometimes when you press the test button, located on the front of the device, the alarm will reset itself.
If its inbetween 6 until 10 years old i recommend in that case to replace the unit because of its chemical compounds and radioactivity materials that will in most cases saturated beware of slightly radioactive material if trying to inspect for defects.
