SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
SOURCE: Avanti wine cooler temperature problem
repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area location.
SOURCE: MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
SOURCE: My Dome 40 bottle
Hi and welcome to FixYa, I am Kelly.
The defrost thermistor has failed. This E2 error code means that your appliance has experienced a defrost sensor fault. The bad thermistor will be near the top of the evaporator coils.
Thanks for choosing FixYa,
Kelly
Testimonial: "From one side of the world to the other;Thank you so much Your reply was spot on and greatly appreciated.Keep up the good work"
