20 Most Recent Danby DWC513BLS Wine Cooler Questions & Answers
E4 code for lower chamber of danby wine cooler
I had the same problem on my DWC513BLS wine cooler (12 years after your original post). I fixed mine after much troubleshooting. If someone have a similar problem, here are the error codes for that unit :E4 = Defrost sensor defectE3 = Defrost sensor disconnectedE1 = Lower chamber sensor disconnectedE2 = Lower chamber sensor defectE7 = Upper chamber sensor disconnectedE8 =Upper chamber sensor defectTo correct E4, I had to replace the defrost sensor with part #DWC276.
12/13/2023 2:59:17 AM • Danby DWC513BLS... • Answered on Dec 13, 2023
I am in need of a fan motor for my Danby Frig. Paret #JG50.DQ-10. Cannot find it anywhere. Suggestions?
The problem with the factory fan is that it is a sleeve-bearing fan. On average, a fan should operate for about 50,000 hours, which if it runs continuously would be over five years. However when the operating temperature rises or the fan is installed "not exactly" vertically, it will have shorter life. I had to replace my fan two times withing two years since we bought the unit! Plus the stock fan becomes quite noisy after a couple of months of work. With all of these problems I did some research for better fans and decided to purchase a ball-bearing fan to install it into the cooler by myself. Ball-bearing fans on average outlast sleeve-bearing fans by 50 percent and produce less noise. It's very important to purchase the right AC 115 Volts fan for this Danby wine cooler. The original fan is Rullian Science RAL 1225S2 (120x120x25 mm in size, 100-125V AC, 0.09A) The replacement model is Orion OA12AP-11-3TB which I got for $16.75 from Mouser Electronics (mouser.com). The replacement model is ball-bearing cooling fan with slightly higher/better parameters, which will help to cool down the wine cooler coil faster. To replace the fan you need to tilt the wine cooler on the side and unscrew two small screws at the bottom that keep the original fan in place, remove one screw to the black box where the fan wires are attached and unplug these wires. Then you just need to replace it with the new fan and test that it works properly. If you never used Soldering Tool before you probably will be better off with getting some help from certified electrician - it still will be less expensive than getting this fan ordered every year from Danby.
3/9/2015 3:42:14 AM • Danby DWC513BLS... • Answered on Mar 09, 2015
0answers
0answers
manual
3answers
Unit will not stay cool. Is it a thermostat,
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
3/26/2013 12:15:05 AM • Danby DWC513BLS... • Answered on Mar 26, 2013
0answers
Fridge does not get cold , " E4" displayed on
change digital board in the front
8/18/2011 6:36:54 PM • Danby DWC513BLS... • Answered on Aug 18, 2011
I am looking for the cooling fan for a Danby
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
4/9/2011 1:06:08 AM • Danby DWC513BLS... • Answered on Apr 09, 2011
Danby DWC513BLS Wine Cooler Logo
37 questions posted
Top Danby Refrigerators Experts
vince
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Danby Refrigerators
  • Danby Refrigerators
Most Popular Question
unit will not stay cool thermostat
  • Refrigerators
