SOURCE: Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
SOURCE: Grinding noise,unit stopped, burning smell?
Just had the repair man come out for the same problem....tranny gone, $600 to repair. Only 3 years old. Disgusted. Good luck.
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
SOURCE: power steering went out and making a loud noise when turning.
yes power steering is most likely very low , repair leak , as the fluid is flameable
SOURCE: making a terrible loud squeaking problem like a
Hello, I think by your description it's likely the rear drum bearing & hub. It is quite common on frigidaire/white westinghouse made dryer's.**unplug the unit before servicing** Try and search for a tiny little ball bearing at the back of the unit and see if you can isolate the noise is from there. If so you may be ok with some hi-temp silicone based lube for now, (you'll need to apply it from inside anyway, so you might as well replace it) but the bearing assembly probabely needs to be replaced...if that is the source of the squeaking. I hope that helps, Good Luck :)
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
