SOURCE: CECT i9 Phone: GPRS problems...
Internet Setup
***First Step***
Main Menu --> Select Services
Select Data Account --> Select GPRS
Select the first entry
Edit the account name to whatever you would like
Edit APN to wap.voicestream.com (lowercase)
The Username is blank
The Password blank
Edit Auth Type. to Normal
Save
Select Back --> Select Back
***Second Step***
Select WAP
Select Settings --> Edit Profile
Select the first entry --> Edit Profile
Edit the name to whatever you would like
Edit Homepage to http://wap.myvoicestream.com
Edit Data Account to the Name you established in the First Step
Edit Connection type to HTTP
The Proxy Address is 216.155.165.050
The Proxy Port is 8080
Username is blank
Password is blank
Select Done & Save
Select Activate Profile
SOURCE: SGH-E250 internet access via data cable or blue tooth to PC
You have to buy a data cable or use bluetooth.Create a dialer which dials *99# using your samsung modem over bluetooth
SOURCE: ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
