20 Most Recent
T-Mobile Blackberry 8900CURVE Curve 8900 For TMobile Activation Questions & Answers
What is proactive sim command rejected by me ?
This means you may need a new sim card, or there is something wrong with the slot you put the sim card into. Take the phone in to T-mobile and have them check it for you. You may just need a new sim card. Worst case, your phone is failing/failed.
12/12/2018 8:55:19 PM •
T-Mobile...
Answered
on Dec 12, 2018
Network problem
what do you mean by losing?is it the signal of the network or the whole set up of the phone for the network?
4/12/2013 4:54:10 PM •
T-Mobile...
Answered
on Apr 12, 2013
Reload software 522
hi go on google a google the phone and mdel number and n the end put software download and there will be a page that you can download the software with tep by step instructions.martyn
4/11/2013 4:14:04 PM •
T-Mobile...
Answered
on Apr 11, 2013
Blackberry 8900 unlock code
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
10/1/2011 1:05:33 AM •
T-Mobile...
Answered
on Oct 01, 2011
How do i get the mep code for a blackberry curve
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
Hope this helps.
9/4/2011 10:39:05 PM •
T-Mobile...
Answered
on Sep 04, 2011
App error 523
start the blackberry in secure mode.This will fix app error 523
5/16/2011 2:28:30 AM •
T-Mobile...
Answered
on May 16, 2011
Unable to scroll to the right allways
the track ball on the curve is very prone to such problems. we frequently use un-clean fingers when using the track ball. the dirt gets collected on the track ball and on the underside. use an alcohol swab to clean the track ball and your problem should get solved.
4/8/2011 8:47:16 AM •
T-Mobile...
Answered
on Apr 08, 2011
Blackberry 8900 jvm error 523
Hi, error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again.
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
3/9/2011 7:24:59 AM •
T-Mobile...
Answered
on Mar 09, 2011
SIM CARD ERROR
hi
check that Sim card is inserted properly or not. if so there must be some software problem in your phone .format your phone and try now.. this will fix your problem.if still having same problem then check the Sim card slot pin in your mobile.. contact your service and change the slot . this will fix your problem..
thank you
12/25/2010 10:55:29 AM •
T-Mobile...
Answered
on Dec 25, 2010
