20 Most Recent T-Mobile BlackBerry 7105t Cellular Phone Questions & Answers
I do have a gmail account and do receive emails to
Call gmail customer service and ask for a new passcode.
1/20/2018 2:32:28 AM • T-Mobile... • Answered on Jan 20, 2018
Mep unblocking codes
You can get the Mep unlock code for your Blackberry 7105t phone from UnBBLock.com here you need to specify your country,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.Using this you can unlock your phone from Network lock easily.
12/4/2013 7:36:09 AM • T-Mobile... • Answered on Dec 04, 2013
0answers
2answers
Iwant to hard reset this phone
A reset of a BlackBerry smartphone does not delete any settings or data.There are two options for performing a reset: a hard reset and a soft reset. A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry
smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
5/22/2013 3:06:37 PM • T-Mobile... • Answered on May 22, 2013
12answers
Can u unlock my blackberry for free?
As far as i know unlocking through unlock codes is the best.safe and simple way.when i suffered with the problem my friend suggested me the site from where i got my unlock code.....do not use wrong codes it may damage your phone too.i know the site which gives good services.The site is trustable.you can easily get your code from there its not free but it as much cheap as free..click here to get your unlock code.
hope this helps...
3/22/2013 8:06:30 AM • T-Mobile... • Answered on Mar 22, 2013
10answers
I want unlock code blackberry
It is very easy to unlock your blackberry 7105t. Go online .thousand of site available online. order your unlock code also called MEP unlock code.
after getting your unlock code . simply enter MEP code through your blackberry key pads.
after unlocking you can use your blackberry to any GSM network in the world.
i hope this will help you .
3/22/2013 8:04:25 AM • T-Mobile... • Answered on Mar 22, 2013
Reload software source
hi deargo to http://www.t-mobile.com/bbupgrade/ you will see your device click on get softwarea box will open enter your device imeiit will download you device software read instructions provide there to reload the software
4/26/2012 9:19:07 AM • T-Mobile... • Answered on Apr 26, 2012
0answers
3answers
Hi how do i unblock my t-mobile blackberry pearl
There can be many ways to Unlock your phone.As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry PEARL 8100 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry PEARL 8100 online instantly - they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
10/14/2011 10:52:48 AM • T-Mobile... • Answered on Oct 14, 2011
HOW DO I RESET MY PHONE
Hi Rob,
Reset, you mean firmware reinstall. Download the latest firmware drivers from Blackberry.com and then install those drivers via the Desktop Manager on your PC.
I hope this helps,
Thanks.
8/17/2011 11:59:55 PM • T-Mobile... • Answered on Aug 17, 2011
How to reset my blackberry 7105t
Blackberries use a method called "Wipe Handheld" to restore everything to factory settings. Here is the method
To wipe the handheld data, go into Options / Security / General Settings, click the wheel and select "Wipe Handheld".
8/17/2011 11:58:10 PM • T-Mobile... • Answered on Aug 17, 2011
I can't turn it on the phone. it's not working at
its a Motorola its supposed to do that get an iPhone.
11/22/2010 6:03:30 AM • T-Mobile... • Answered on Nov 22, 2010
I want to lock my black berry 7105t
Why would you want to lock your phone??
10/11/2010 10:19:56 PM • T-Mobile... • Answered on Oct 11, 2010
Blackberry screen- cracked!
It looks like you need a new LCD screen which in theory you can replace yourself. Here's a guide on how to disassemble a blackberry. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party Blackberry Repair Services.
7/19/2010 1:12:08 PM • T-Mobile... • Answered on Jul 19, 2010
Unlock blackberry 7105t
ya
I can help you Don't worry............. my friends mobile has alsolocked
and after searching in google and reading forumswe found this site working good
they delivered code at right time
customer care was good
so you can also try it Click Here
good luck
6/23/2010 11:38:31 AM • T-Mobile... • Answered on Jun 23, 2010
7105t Blackberry is not switching on
when a phone does not come on, there are two area that you will need to check where the fault is from:
the battery,
and
the phone board.
The cell of the battery might be too weak to power the phone, so you need to check if the battery is really charged or the battery on the cell is finally dead and will need to be replaced.
For the phone board, the phone board might be dead and will need to be restored back by flashing the phone.
Flashing the phone will restore back the phone and it will start working normal again.
Have a nice day.
3/25/2010 1:43:09 PM • T-Mobile... • Answered on Mar 25, 2010
Need unlouck code for t mobil cell phone
Enter http://blackberrymep.com and follow instructions there, you will get your blackberry unlocked in five minutes .
3/17/2010 2:40:26 PM • T-Mobile... • Answered on Mar 17, 2010
Accessing 7105t Blackberry e-mail on a PC
No unfortunately it is pushed technology straight to your device.
If you get another blackberry you can transfer your email accounts to the new blackberry retaining use of the mail account
2/22/2010 5:17:45 PM • T-Mobile... • Answered on Feb 22, 2010
Set up voicemail
Depending on the carrier it can be a little bit different. Basically you need to dial the voicemail number from your cell, most commonly 123. After this an automated machine will guide you through the setup.
Hope this helps,
Joe
2/19/2010 10:08:59 PM • T-Mobile... • Answered on Feb 19, 2010
T-Mobile BlackBerry 7105t Cellular Phone Logo
Popular Tags
64 questions posted
Top T-Mobile Cell Phones Experts
Rob Hill
Rob Hill
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • T-Mobile Cell Phones
Most Popular Question
u unlock blackberry free
  • Cell Phones
