HELLO: I think i might have the information you need,bellow the mounting bracket,next down the mid section to the lower unit on the same side as the mounting bracket,you have the antie ventelating plate,then comes the WATER INTAKE right opposit the prop. im sorry but i was unable to find a diagram for your needs ,im hoping this will help .GOOD LUCK M.M.
SOURCE: how to find serial number
I have the same unit.The Simplicity auger belt is a 41.5" belt and a replacement one I believe can be found on amazon.com under this description
Oregon 75-993 Replacement Belt 5/8-inch x 41-1/2-inch
http://www.amazon.com/Oregon-75-993-Replacement-954-0468-754-0468/dp/B0018TYD1E
SOURCE: what year and model is mariner 75 serial number 9502368
Hey Arthur,
This serial number does not show up..???Please look for more numbers on any plate or freeze plug..
These guys can help.. need more info though...
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
http://www.boats.net/parts/search/Merc2/Mariner/parts.html, searial is on the flat part near the out put shaft from the crank. usually covered in grease and dirt.
