SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
SOURCE: Computer not recognizing SD card as external storage/Creative Zen
Try going to the memory card option on the main menu, then go to 'Removable Storage', then the Zen should either tell you to connect a USB cord or insert a memory card. Try it, if not I dont know.
SOURCE: "please insert memory card in GZ-MG130U CAMACORDER
Hi there.
The hard drive will be full so you will need to transfer all your videos to your PC then format the hard drive in the camera's menu, make sure the SD card is removed before you format it.
Good luck and thanks for using FixYa!!
SOURCE: Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
SOURCE: I have a Brookstone digital picture frame that stopped working
I have encountered this same error on the frame I bought 2 years ago. I saved the pictures to a backup and then reformatted the frame - this didn't work - does anyone have any other solutions???
