SOURCE: car goes in limp mode when seeing boost
Some K&N air filters are an "oil-soaked" filter and it is that oil that can cause the problem you are having. If you want to be sure, remove the filter, clear the code(s) then drive the car. If the code(s) do not return, install a non-oil-soaked filter.
SOURCE: My Chrysler cirrus goes into low 1 or low 2 on its
"Limp Mode" is determined by the Powertrain Control Module (PCM). It could be going into limp mode as a result of a transmission malfunction or it may be going into limp mode as the result of an engine control problem. The only way to find out is to scan your onboard computer system and retrieve any engine or transmission fault codes and diagnose and repair accordingly.
Please note that engine control problems can CAUSE transmission control problems. If there are any engine control faults, these MUST be diagnosed and repaired FIRST.
Please also review these articles:
What Else Could Be Wrong?
What To Expect From An Online Car Expert
SOURCE: car goes into limp mode wont come out of 2nd
That happened to my '95 OLDS Aurora... Turned out to be 1&2 gear shift solenoid had "popped" out. He replaced new solenoids and a factory patch kit and ****** shifts like brand new. Hope that helps you cause that was less than 10% the cost of a new/rebuilt transmission!
SOURCE: Peugeot207 1600 Diesel HDI goes into limp mode
This make is not sold in the USA so have little or no info on it. Sorry
