a
alfredo lobog Posted on Mar 26, 2018
WHAT'S THE RESISTANCE VALUE OF R704 OF SHARP TV 21V-FW250S?
STR 5453A WAS DAMAGE
1helpful
What is the value of r704 resistor on sharp slim tv 21v-fk220m
pa help naman po mga master..my rerepair po ako sharp tv..model21v-fk220m sira po ung regulator..strw-5453 sunod din po ung resistor na mlapit sa regulator..problem po d makilala ung resistor..anu po kya value nito meron po code na r704...slamat po sa sasagot godbless po..
The value of r704 resistor on sharp slim tv 21v-fk220m
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given. Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a · Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
1helpful
What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to many popular devices are given. You can fetch details there.
1helpful
What is the flyback number of sharp 21v-fw250s
Why bother? Old CRT tvs are worthless.
2answers
I have a crt tv sharp model:21v-fw150m blk.. is
Try to download the repair manual to this TV by internet. It has all details.
Burn r704 resistor in my sharp tv 21v-fr70m,, i want to know the value,,, help poh mga master...
leo_arsolaci.jpgleo_arsolaci,
sir here is the exact value of resistor r704-220 ohms and please check also the zener diode 8.2 volts....
I want to know the resistance value of r704 in my sharp 21v-fr7om.. it burn...
sir here is the exact value of resistor R704- 220 ohms and please check also the zener diode D732- 8.2 volts....
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
