I have a vintage Panasonic 8 track tape player. Track 1 only has right side output[music coming out of right side only] Tracks 2,3 and 4 are fine, with output on both right side and left side. Any ideas??
SOURCE: Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
SOURCE: Naming tracks on my new MP3 player
The software that comes with your player uses an online database from "Gracenote" (link below)to name the tracks. When you copy from a CD the software recognises the disk & looks up the database to find the track info, if you are not connected to the internet or your firewall software is blocking the request it will not be able to retrieve the track info & will just name the tracks "track 1" etc. You can rename the track yourself in the program by highlighting the track in the PC software and pressing the right mouse button & choose "property" this opens a window where you can edit the track title but not the file name. You can update the tracks you already have by connecting to the internet then highlight & right click as before but now choose "get track info", the software will connect & retrieve the track info and ask if you want to change it. There is a problem with language CD's as they will often not be in the database and you will need to name them yourself. There are many helpful programs available (some free) to rename the tracks (technically known as ID3 tags). Search on the web for "mp3 tag software". http://www.gracenote.com/music/
SOURCE: tascam 488 mk II recording problems
Have you taken a look at the edge of the tape? tracks 1 and 2 on a cassette are usually next to the edge and you may have a bad batch of tapes that have the edge damaged. Another possible but not a likley problem might be the tape is out of spec. for the width, and your heads MAY have a little wear from use, and are trying to act like tape guides. If the tape is slightly wider than the grove worn in the head, the tape would be lifted at the edge and not make contact to the head. It is not electronic as you have diagnosed this with other tapes. Give it a try and see!
SOURCE: Player will only play track #1
Maybe your "play once" option or "repeat" option is activated, try and check it and get it back to normal play...
SOURCE: tape deck is broke sounddesign model 5959
If the motor is running but the belts are not, then they are probably shot. You can buy belts by size or buy a belt kit at MCM Electronics.
If the motor is not running it could be 2 things: 1. A bad motor or voltage to the motor.... 2. A bind. I've seen the grease on the capstan bushing get old enough to turn into a very hard tar. So check the motor and capstan for freedom of movement.
Hope that helps you get it working...
Geno
