Computers & Internet Logo
H
Harry Belkin Posted on Mar 07, 2018
What is Yak's Cisco SPA122 password? - Cisco Computers & Internet
An incoming call comes up on the screen but does not ring. The phone is being used in conjunction with a Cisco ATA (converting analogue to digital) for IP Telephony.
It sounds like everything is working on the SPA122 side. I would look at the Uniden phone first. Have you tested this phone on a regular phone line to see if it rings? Does the phone have a Do Not Disturb function?
2answers
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
PLEASE SOMEONE HELP ME OUT HOW TO UNLOCK THE (CISCO)POHONE IVOP ADPTOR MODLE # SPA122
It's locked in which way? If you're locked out in terms of username/password, you'll need to do a factory reset. Your manual will show you how.
If you want to free your "branded" unit in order to use it with any VoIP provider: there's not a lot of documentation out there. You could try uploading stock firmware from Cisco to overwrite the branded firmware, but I can't guarantee any success. You'll need to be somewhat tech-savvy for this and it might even void the warranty of your unit and possibly brick it, so it's all on your own risk. You could try the firmware upgrade through the webGUI or through TFTP commands (command prompt).
If you're not comfortable experimenting, I suggest looking around for an already unlocked unit. Used units on Craigslist/eBay are usually not so expensive.
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
1helpful
What is the default enable Password for cisco 7604 - sup720-3b
The default user name and password for Cisco routers and switches is usually:
user name: Cisco password: Cisco
Make sure to capitalize the C's.
3answers
What are some wifi passwords
The default passwords for cisco models can be found here: http://hubpages.com/hub/CISCO-Router-Password-Default-Password-for-CISCO-Router
Hi, what's a password on the router Cisco Catalyst 2960 default?
Try using username (none) pass public/private/secret or
cisco - cisco, ADMIN - changeme, pixadmin - pixadmin, root - attack, superuser - superuser as username - password. These are the defaults credintials for the Cisco routers.
Stelios.
4helpful
Default username & password after hard reset
Username:[none]
Password:Cisco or
:root
:Cisco or
:Cisco
:Cisco
Try from above 3 then you can access cisco router.
Let me know if you need further assistance.
Thanks for using FixYa.
2answers
I have a router cisco and I dont remember the passowrd
Are you a Cisco Router user and forgot its password? Well, there are several ways to reset, change and recover Cisco Router password. But, for an instant solution, you must take the professionals help by calling them up at their Cisco support number. You can get this phone number from Contactforhelp, a trusted online directory famous for customer support and services.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
