1st try unplugging it and plugging it back in.
2nd The key pads can appear to be locked when it's just pushing the right buttons that fixes it.
I have run into that more than once myself.
I'm clever and it took me a while to find the right one.
It usually had something to do with setting the clock.
Try pushing each one from left to right & top to bottom just like you read. One of them probably will give you options.
Not likely but it is possible it could be 2 buttons at the same time but I've never run into that.
SOURCE: LG microwave not heating
If there is no power at all check thermal cutoff and control board.
SOURCE: I have a samsung over
Hi SE error code means shorted key and is displayed when either
a key is shorted or the key pad has gone bad. Usually replacing the keypad
solves the issue however, before doing this you can also try to leave it unplug
for 15 minutes. If the issue returns then the keypad should be replaced. Hope
this helps...please post back for further assistance. Daniel
