Try With: https://up-dl.net/chinese-miracle-2
There are many ways to bypass the frp lock. But all are not easy. I will define a easy method for you.
Try the following tasks,
1. Get you PC ready.
2. Full Charge you mobile battery.
3. Dowload a flash tools from this link http://samsung-tool.en.lo4d.com/
4. Download a latest firmware of your device from here
https://www.sammobile.com/firmwares/galaxy-s6/SM-G920P/
5. Download appropriated USB/VCOM Drivers for you device from here https://www.mobileusbdrivers.com/2017/10/samsung-galaxy-s6-g920p-usb-driver.html?m=1
Now almost ready for flash.
Install the downloaded drivers.
Turn off you phone, remove SIM/Memory Card if needed battery also. Now connect you phone with your PC using USB cable. Now open the flash tool and flash new download firmware. And you are done!
SOURCE: Factory Reset
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received
SOURCE: How do I do a factory reset to get past the lock code for a Samsung Google sch 1515
whats locked phone or sim card
SOURCE: g et past samsung accout id an passworda
https://account.samsung.com/account/check.do
You can reset your account password from this link
SOURCE: My samsung galaxy note 5 says customer binary blocked FRP lock on KERNEL IS NOT SEANDROID ENFORCING
Just put the phone in Download mode
by pressing Power + Volume down + Menu
and then volume up to confirm
Download Samsung Firmwares
then use odin tool to flash Flash Samsung Android using Odin tool
did you forget your google account? or you bought used device?
