SOURCE: 18 volt charger (Dewalt)
The DW9116 is actually a 120 volt charger so it should cope with 130v AC supply, what is the supply from?
It is normal for a standard 110v supply to run at around 117V
See THIS INFO on power supplies
SOURCE: convert 2 pin dewalt charger to 3 pin how
By 3 pin do you mean the third pin being a ground. If so that charger does not have anything internal to ground to. It is a 120Volt Double insulated tool. Let me know if you are trying to do something different.
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
SOURCE: 24 volt dewalt cordless battery charger not
I don't know that I'd fix it as they are around $35 on EBay. Just my opinion. Here's a link to one.
http://cgi.ebay.com/DeWalt-DW0245-1-HR-24V-Battery-Charger-Tune-Up-Mode-NIP_W0QQitemZ290404555151QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item439d75d98f
SOURCE: I purchased a new charger for my Dewalt Cordless Drill
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
