bill ludecker Posted on Jan 31, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How many gallons of water in a fish tank 8 feet long by 2 1/2 wide by 4 foot high
DocZachary
Level 3:
Master:
  • In Master 533 Answers
  • Posted on Jan 31, 2018
DocZachary
In Master
Level 3:
Master:
Answers
533
Questions
Helped
167817
Points
2496
Tank Size to Gallons of Water Formula
Determining the amount of water in your aquarium is as simple as knowing that volume equals length times width times height and that 1 cubic inch of water is equivalent to 0.004329 gallons. Therefore, the volume of your tank in gallons of water = length x width x height (measured in inches) x 0.004329.
so 8'=96"
2.5' = 30"
4' = 48"
Volume = 96x30x48 = 138240 * .004329
This is approximately 598.4 Gallons.
Semper Fi,
Z
Simon Atkinson
Level 3:
  • In Master 3,944 Answers
Simon Atkinson
In Master
Level 3:
Answers
3944
Questions
14
Helped
1073916
Points
14122
I think you will be looking at about 500 gallons.
598.4 US gallon.
498.3 UK Imperial gallon.
5 Related Answers
Anonymous
  • Posted on Dec 10, 2008
SOURCE: cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Joel Friedenberg
  • 1114 Answers
  • Posted on Jul 08, 2009
SOURCE: flotec 42 gallon water tank - short cycling and
These holding tanks are pre charged with air which in turn pressurizes the water. The tank has a bladder and an air valve on top. The pre charge ,over time, loses pressure, and the tank has to be pressurized again.
  • The well pump needs to be turned off.
  • The water has to be drained from the tank
  • Air is put into the tank from the air valve on top of the tank, and is measured with a tire air gauge.
  • The pre charge pressure is set to two psi below the pump cut in pressure.
  • In other words if your pump kicks on at 30 psi, the pre charge pressure is set at 28 psi. If the pump kicks in at 20 psi, the pre charge is set at 18psi, etc.
  • After you pressurize the tank, turn water back on.
  • If water comes out of air valve on top of tank, then the bladder is ruptured and you need a new tank.
  • Hope this helps!
Anonymous
  • 89 Answers
  • Posted on Jul 19, 2009
SOURCE: air in lines
SOUNDS LIKE A CRACKED SUCTION STUB OR LOOSE THREADED FITTING SUCKING IN AIR.
OR THE CHECK VALVE IS FAILING AND ALLOWING THE WATER TO LEAK BACK SLIGHTLY OR ALL THE WAY BACK. YOU CAN ALSO ADD A FOOT VALVE AT THE END OF THE PIPE.
LONG SHOT, BUT THE BLADDER TANK IS CHARGED WITH AIR AND MAY HAVE A HOLE IN THE BLADDER CAUSING THE TANK AIR TO ENTER THE SYSTEM. SHOULD RUN OUT QUICKLY THOUGH. HOPE THIS HELPS, JODY
Anonymous
  • Posted on Sep 10, 2009
SOURCE: in the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again?
When I flush the toilet and the water is filling up, water comes shooting straight out of the top of the flush valve, hitting the side of the tank and causing water to rush over the side of the tank and on to the floor
Anonymous
  • 15 Answers
  • Posted on May 22, 2010
SOURCE: I can't find a 1/4 inch foot fo rmy sewing machine anywhere...
I've been looking for one as well...this store seems to have it although I have not yet ordered it:
http://www.raichert.com/azsewingstore/p-JTLF15.htm
2answers
Gallons in a tank 4 foot high 21/2 wide 8 foot long
5146.6 US Liquid Gallons (1 liquid Gallon is 3.79 L)
Can you help me i need a pump that will produce 1 GPM thru 250' x 1/2" tubing @ 10psi
You can convert pipe size to gallons per minute of flow by calculating the cross-sectional area of the pipe and making some reasonable assumptions about pipe volume and the rate of flow. Pipe sizing is measured by the internal diameter of the pipe, not the overall outside diameter. Once determined, the overall volume can be calculated. Pipe flow is described in gallons per minute. Shorter lengths of pipe will have a greater flow than a longer length of the same diameter. This is caused by internal resistance of the pipe itself. By the same reasoning a larger diameter pipe will have a greater flow or GPM than a smaller pipe at the same pressure or flow rate. Pressure is described as pounds per square inch. The square-inch measurement is determined by the area of the pipe. The pounds are the amount of force that is placed on the liquid to push it through the enclosed space.With that background, you can estimate the flow based on the pipe size.
Find the cross-section area of the pipe. Area is equal to pi times the radius squared or a = 3.14 x r2. A two-inch diameter pipe would have a cross-section area of 3.14 x 12 or 3.14 square inches.
Understand that water has a certain pressure associated with the height of that water. One pound of water pressure, or 1 PSI, is equal to 2.31 feet of elevation in height. In other words, a 1-inch column or pipe of water that is 2.31 feet high will have a pressure of 1 PSI. The overall height -- not volume -- of the pipe corresponds to the pressure. A 6-inch diameter pipe that is 2.31 feet high will only have 1 PSI.
Find the volume of the 2-inch diameter pipe in Step 1 that has a length of 10 feet. Ten feet is equal to 120 inches. Multiply 3.14 square inches, the cross sectional area, times the length. The volume of the pipe is equal to 376.8 cubic inches of volume.
Convert cubic inches into cubic feet. One cubic foot equals 1,728 cubic inches. Divide 376.8 cubic inches by 1,728 cubic inches per cubic foot and the answer is .218 cubic feet. This means that the 2-inch diameter pipe that is 10 feet long has an internal volume of .218 cubic feet.
Calculate the amount of water that can be contained in the section of pipe at any given time. One cubic foot of water is equal to 7.48 gallons. Multiply 7.48 gallons by .218 cubic feet and the amount of water in the pipe is equal to 1.63 gallons.
Find the GPM if the flow of water is one foot per second. Multiply the one-foot per second flow by 60 seconds per minute and the flow is now 60 feet per minute. In other words the water will flow through the 10-foot pipe six full volumes for every minute. Since the piping contains 1.63 gallons per 10 feet of pipe, multiply 1.63 by six and the final GPM is equal to 9.78 GPM of water flow from the 2-inch diameter pipe.
Jan 19, 2018 • Plumbing
Steve is replacing 9 shelves in a cabinet that is 212 feet wide. He purchased 3 8-foot boards to make the new shelves. How much board will be left over after Steve makes the new shelves? feet
Not enough info... or not enough wood.
Never saw a cabinet 212 feet wide- almost as long as a football field .
I'm going to assume you meant 2 and 1/2 feet wide. If so, each 8 foot board can be cut into three 2 1/2 foot shelves (leaving 1/2 foot left over). Do same 3 time yields 9 shelves and three 1/2 foot boards - a total of 1 1/2 feet left over.
3answers
How many gallons of water in a 4'by 24' round pool?
the volume of the tank is calculated by the formula
22/7 x 24 x 4
= 301.7143 cubic feet
1 cubic foot = 7.48052 US Gallons
therefore your tank will hold 2257 US gallons approximately
Mar 04, 2015 • Pool & Spa
72in x 29in x 24in how many gallons calculator
72 x 29 x 24 = 50,112 cubic inches / 1728* = 29 cubic feet. There are 7.48 gallons per cubic foot, so the tank is actually 216.92 gallons, assuming the dimensions given are inside measurements. I hope you have a strong stand and floor because the water alone weighs 1735.36 pounds (8 pounds per gallon).
*12 x 12 x 12 = 1728 (cubic inches to cubic feet conversion)
2answers
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Top In Office Equipment & Supplies Experts
Paul Carew
vince
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
