I have the same problem. I think there is a plate with threaded holes behind the panel that the screws screw into, and this plate falls when you remove all 3 screws. But I cannot see any way of getting behind the panel to retrieve this plate. Help!
SOURCE: inquiry on parts for ancient Frigidaire Cookmaster
Try www.monitortop,com and send email
SOURCE: Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
SOURCE: Broken door knob. no access to hinges, screws. Rental property!
Take apart a similar doorknob in your house. Use the stem with knob on it and insert into the square hole in the lock--turn!
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
I am not sure about your oven model. I had a similar problem in my oven. The hinges are riveted to the oven and can be fixed.
First remove the oven door - normally the door slides on to two prongs on either side and is screwed down.
Once the door is removed check the mechanism that holds the two prongs to the oven body. Mine were held with stainless steel rivets that had worn out and became wobbly. Cut the rivets and replace them with new ones. You can get a rivet driver and the stainless steel rivets for under $20 at Home Depot.
Hope this works for you.
