20 Most Recent
Lofra MXD96MFEPI Dual Fuel (Electric and Gas) Kitchen Range Questions & Answers
Lofra oven doesent stay alight
I had the same problem with my Lofra, I removed the cover on the bottom of the inside of the oven and then unscrewed the metal bit under that. Then I tested it again so I could see why it wasn't lighting up. Turns out the heat sensor was in between two flames and wasn't detecting that the gas was on. I wiggled things around a bit until it stared working, then put the cover back on. Now it works wonderfully. Now I just have to fix the timer.. It doesn't ring when it reaches the end. Hope this solution works for you guys.
Need Natural gas conversion kit
Natural Gas conversion kits usually work generally for various units. Any natural gas kit which would work for any kitchen range would work for your unit regardless. this is because things such as gas and kitchen ranges are made according to a universal standard and therefore conversion kits also follow the same standard.
Gas conversion kits can be gotten online from websites like nextag.com, amazon.com, ebay.com and buysmrt.com.
Search these sites for comparable prices.
Feel free to request further assistance.
Hope this solution has been helpful?
Lofra gas/electric stove glass lid springs failed
you will have to replace the springs. you should remove a spring and take it to a local hardware store as they may be able to match it. Always replace all of the springs at once, not just one because as they are used they loose a bit of their action.
if the springs must be original equipment, you can get them here
Phone: 1300 306 973
Fax: 1300 887 306
[email protected]
Pronto Parts
65 Northgate Drive
Thomastown
VIC 3074
Australia
