SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
SOURCE: toshiba ct-90275 code for direct tv d10
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Toshiba CT-90275 3 digit code for Direct Tv R-16
this might be helpful. Maybe not. But anyways.
http://www.fixya.com/support/r550433-programing_remote_controller
SOURCE: toshiba CT-90275 remote
I have the same piece of junk remote and it has been slowly losing functionality over the last two months. Strangely enough, the only thing mine WILL do is scroll through the channels. Toshiba is about useless but if your TV is still under warranty, I'd call them and complain if this doesn't work. They are out of the remotes so plan on waiting awhile.
Turn off the TV and all the other things the remote is set up to control. Best to just leave that room altogether. Remove the batteries from the remote. Then, in turn, press each of the silicon buttons on the remote from top to bottom. Do NOT move the mode select switch at the bottom. Make sure you've hit each and every button. Replace the batteries and go try to see if it will work. Supposedly, this removes the static electric charges from the contacts under the buttons and will occasionally get the remote to work again. I had no luck at all. I've been waiting six weeks for a replacement and still no dice. The fastest way to fix the problem is to just go to an outside supplier and buy another one for $30. Then should Toshiba actually ever send you a replacement, you'll have one for the next time it crashes and burns.
I have a Toshiba 37HL67 model LCD and there is also supposed to be a firmware upgrade needed for those type models. The odds of that being the problem are so remote as to not be considered, but you never know. You will have to contact Toshiba to find the nearest repair dealer and have them do the upgrade. The upgrade is pretty simple. You unplug the TV, remove the cover for the card insert on the back of the TV, insert the firmware card. Replug the TV, follow the instructions on the screen, unplug the TV when it's done, remove the card, reset the little cover, plug in the TV and let it reboot. Toshiba guarantees that they will make the service guy come to you, but they usually are too lazy and want you to bring the TV to them. Toshiba will force them to do it, but if you can just get them to give you the firmware card you can download the instructions. Hope this helps.
SOURCE: Need toshiba ct-90275 remote codes & manual
go to www.replacementremotes.com/store/productdetailp.cfm?productid=61473 And in right middle under buy it you can download it for free.
