20 Most Recent
Aiwa VX-S135 13 in. Combo Questions & Answers
Can I replace the vcr unit in the tv or have it repaired?
HelloYou can do both. Either repair the present one of repalce it as a whole unit. In most cases, replacement is done, when the exististing mechanism has been turned irreparable. If it is repairable, repair the existing one will be better. If it has been turned irreparable, replace it with same type. The cost will be greater than repair compare to replacement. OK.
Aiwa CXZM2600 no sound. Speaker module OK.
There are several common faults that can cause a lack of sound on the Aiwa CXZM2600 front panel circuit board:
- Damaged components (e.g. capacitors, resistors)
- Loose connections
- Badly soldered joints
- Blown fuses
- Failed audio amplifier IC It's recommended to check these potential issues and to have an experienced technician diagnose and repair the fault.
I Have An Old Aiwa Stack MX-Z9300m and i don't have the remote
It sounds like you're looking for a replacement remote control for your Aiwa Stack MX-Z9300m. Unfortunately, since your stack is an old model, it might be difficult to find a new remote control for it.
Here are a few options you can consider:
- Check with Aiwa directly. Contact Aiwa's customer service and inquire about the availability of a replacement remote control. They may still have some stock of the original remote, or they may be able to provide you with information on where you can purchase one.
- Check with electronics repair shops. Some repair shops may have the original remote control, or they may be able to repair or replace the remote control you have.
- Check online marketplaces. Check online marketplaces such as eBay or Amazon for used or refurbished remote controls for your Aiwa Stack MX-Z9300m. Keep in mind that buying a used remote control may not be guaranteed to work properly, so be sure to research the seller's ratings and reviews before making a purchase.
- Invest in a Universal Remote Control. You can purchase a universal remote control that can be programmed to work with your Aiwa Stack MX-Z9300m. These types of remotes are widely available and can be found at many electronic stores or online.
- Consult the user manual or the technical specifications of your Aiwa Stack MX-Z9300m. You might be able to find information about the remote control that was originally used with the stack. With this information, you may be able to find an appropriate replacement remote control.
It's important to keep in mind that some of these options may not be an exact match for your Aiwa Stack MX-Z9300m, and may not have all the functions of the original remote control.
It's also important to check the Aiwa Stack MX-Z9300m's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
