20 Most Recent
Aiwa VX-S205 Combo Questions & Answers
Need remote code
HelloUniversal remote setu codes for Aiwa TV/VCR combo are:0227 0269 OK.
Need code for RCA remote to turn off v chip
Hello
You haven't spseified here about the combinnation of your combo. Whether it is a TV/VCR, TV/DVD, etc: When post this type of problem questions specify it.
If it is a TV/VCR combo codes are: 0227 0269 OK.
Remote Code Aiwa CX-NA505u
Does not play cds properly skips like crazy volume knob sometimes goes louder when i turn it down dosent read all cds eather whats the problem?
Tv not responding to new remote control
Was the replacement remote identical to the original one; or, does it need to be programmed. Also, if your replaced your old remote because it was not working, it might be that the IR sensor on your TV is bad.
Remote control codes
Please give us the make and model of your universal remote and we may be able to help more
other than that the best i could find were 195 and 196 - try them out
Hope this Helps:)
Aiwa CXZM2600 no sound. Speaker module OK.
There are several common faults that can cause a lack of sound on the Aiwa CXZM2600 front panel circuit board:
- Damaged components (e.g. capacitors, resistors)
- Loose connections
- Badly soldered joints
- Blown fuses
- Failed audio amplifier IC It's recommended to check these potential issues and to have an experienced technician diagnose and repair the fault.
I Have An Old Aiwa Stack MX-Z9300m and i don't have the remote
It sounds like you're looking for a replacement remote control for your Aiwa Stack MX-Z9300m. Unfortunately, since your stack is an old model, it might be difficult to find a new remote control for it.
Here are a few options you can consider:
- Check with Aiwa directly. Contact Aiwa's customer service and inquire about the availability of a replacement remote control. They may still have some stock of the original remote, or they may be able to provide you with information on where you can purchase one.
- Check with electronics repair shops. Some repair shops may have the original remote control, or they may be able to repair or replace the remote control you have.
- Check online marketplaces. Check online marketplaces such as eBay or Amazon for used or refurbished remote controls for your Aiwa Stack MX-Z9300m. Keep in mind that buying a used remote control may not be guaranteed to work properly, so be sure to research the seller's ratings and reviews before making a purchase.
- Invest in a Universal Remote Control. You can purchase a universal remote control that can be programmed to work with your Aiwa Stack MX-Z9300m. These types of remotes are widely available and can be found at many electronic stores or online.
- Consult the user manual or the technical specifications of your Aiwa Stack MX-Z9300m. You might be able to find information about the remote control that was originally used with the stack. With this information, you may be able to find an appropriate replacement remote control.
It's important to keep in mind that some of these options may not be an exact match for your Aiwa Stack MX-Z9300m, and may not have all the functions of the original remote control.
It's also important to check the Aiwa Stack MX-Z9300m's warranty status and the manufacturer's instructions to ensure that the repair or replacement will not void the warranty.
