return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
Try cleaning the brass tabs on the battery and the point of contact brass in the camcorder. Use a soft brass brush (gun clean kits at Wal-mart carry them in all sizes). I do NOT recommend useing steel wool because steel wool will leave little bits of itself behind and cause shorting out
It depends on specifications of camcorder, few can be charged with USB and many can not. Please check camcorder manual or supplied documents for charging battery. Thanks.
Are you trying to charge it with the camcorder or a seperate battry dock. Some of them won't charge through the camcorder but only throught the dock. what type of camera and other specifics would help you get better results.
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead.
As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK.
You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
