SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
SOURCE: Casio Wave Ceptor WVA-104H
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
SOURCE: casio telememo combination watch instructions
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
SOURCE: Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
