SOURCE: Camera turns on for a few seconds, then off.
A light rap with a knuckle when powering up fixed the problem, at least temporarily. Lens extended, camera works fine. Not exactly a technical fix, but it worked for me.
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1-
Check the battery door indicator switch under the battery door and
beside the memory card slot. Is the little black switch damaged or
missing? Try pressing down gently using a pen it with the door open and
then press the power button. Does it turn on?
2- The fuse has
blown and needs to be replaced. Offhand I don't recall where it is on
the SD600 PCB or how hard it is to solder on a new one (depends on if
its tricky to get at or not). Good thing is fuses are really cheap.
3-
Other power problem with the PCB due to corrosion or impact damage. The
PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and
make one good camera from the two if you can do that sort of thing
yourself, or secondly have it repaired by somebody.
Don't bother
trying to send the camera to Canon if it is out or warranty (though you can call them and verify
what I'm about to say) because they will want $150+ to do the repair
for you. Parts are not cheap to buy from them.
I know of
one very affordable digital camera repair business... because I own it.
The name is Darntoothysam, feel free to check us out, we are on that
big auction website also (I don't plug their name for free), our seller
ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
SOURCE: Camera will not power on
If you have a warranty that covers dropping, send it in. If not try contacting Canon, go to this link and plug in your information. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=12913
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Did you help? what do siulai do? I also encountered such a problem.
what do siulai do* = What to do?
