20 Most Recent Polaroid a800 Digital Camera Questions & Answers
You don't need to install your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Polaroid a800... | Answered on Jan 27, 2014
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Polaroid a800... | Answered on Oct 25, 2013
Dead batteries or lens error...
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Polaroid a800... | Answered on Oct 04, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Polaroid a800... | Answered on Sep 14, 2011
heatman101
Polaroid a800... | Answered on May 25, 2011
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
Polaroid a800... | Answered on May 24, 2011
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Polaroid a800... | Answered on May 14, 2011
Try NOT connecting your camera to your computer.
Polaroid a800... | Answered on May 09, 2011
Remove the memory card from the camera, go into menu and locate "format" next! follow the prompt to erase all pictures from the internal memory, "even one photo will cause problems".
When this is completed install the memory card back in the camera for normal operation, if this fails return the camera to the store for an exchange.
heatman101
Polaroid a800... | Answered on Apr 30, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Polaroid a800... | Answered on Apr 25, 2011
The Polaroid are good batteries, but! by your description they need to be replaced because it won't hold a full charge.
Polaroid a800... | Answered on Apr 22, 2011
I don't know the particular setup of this model, but some of my Polaroid a800 cameras actually have 2 triggers--1 main trigger which sets off the camera and flash, and then a smaller trigger just around the main trigger that only sets off the camera--no flash. So, look at the trigger and see if there's a smaller trigger (that looks like part of the main release..
thanks.
Polaroid a800... | Answered on Apr 06, 2011
Sir i think there is some loos contact inside the camera.So please go to a near by servicing center they will repair it for you.
hi
get in the menu of the camera
and chose to reset it to factory mode
Polaroid a800... | Answered on Jan 16, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Polaroid a800... | Answered on Nov 28, 2010
Polaroid a800 Digital Camera Logo
38 questions posted
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
A Polaroid
  • A Polaroid
Most Popular Question
polaroid a800 will not
  • Cameras
