This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery from contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder now works perfectly. Most brands of CR2 battery now have higher sides which shield the tip - bad design.
This problem is caused by the 'step' inside the battery cover which prohibits the tip of the battery contacting the nipple inside the cover. I fitted a thin piece of aluminium strip (20thou) and the rangefinder works perfectly now. Note that most new CR2 batteries have higher sides which shields the tip too effectively - check it out.
with what you have described this sounds as if it will need to be sent in for repari. to contact bushnell they can be reached at 800-423-3537. option 1.
