Go the following site: https://www.manualslib.com/manual/91029/La-Crosse-Technology-Wt-5720.html#manual
SOURCE: Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
SOURCE: Lost my manual and cannot manage to find the menu
I found my manual so it is up and running again. Thanks
SOURCE: Lost the manual for Roger Black Cross Trainer
Hello. Call the company directly at 0845 604 0105 Joe
Testimonial: "Thank you!"
SOURCE: How to set a La Crosse radio controlled watch
Go to http://www.lacrossetechnology.com/support/setup.php and choose your watch from the drop down menu.
Unfortunately they do not have any instructions but there is a contact address there where you can get help.
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
