Rear Parking Assist Inoperative - Red Indicator Flashes
Does the red indicator flash ?
Diagnostic Aids
• The RPA system is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes from the RPA display. Before using this diagnostics, it is necessary to get familiar and understand how the on-board diagnostic feature operates. Refer to Diagnostic Trouble Code (DTC) Displaying and to Diagnostic Trouble Code (DTC) Clearing on how the diagnostic trouble codes are displayed and cleared from the RPA display system.
• Make sure the rear park assist (RPA) object sensors located on the vehicle rear bumper are clean and clear. Remove any objects that is blocking the sensors.
• Inspect for after market devices which could affect the operation of the RPA system.
This vehicle is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes using the 3 indicators on the rear parking assist display. After the bulb check has been completed, the red outside indicator flashes to indicate a malfunction with the system. The module disables operation of the URPA system under this condition.
In order to enter the diagnostic mode, complete the following actions:
With the ignition turned OFF, short the rear parking assist diagnostic connector to ground while the vehicle is in PARK. For the location of the rear parking assist (RPA) diagnostic connector, refer to Object Detection Component Views .
Turn ON the ignition.
Place foot on the brake.
Shift the vehicle into REVERSE within 5 seconds.
If the vehicle is not shifted into reverse within 5 seconds after turning the ignition ON, the diagnostic mode will still be initiated. However, a reverse input wiring fault will be registered as sequence #7 as shown in the Diagnostic Indicator table below. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes. After the reverse input wiring code is cleared, repeat the diagnostic trouble code displaying steps in order to enter the diagnostic mode.
When the diagnostic mode is first entered, the rear parking assist display displays the amber outside indicator and the red outside indicator. Then, the indicators on the rear parking assist display will display one or more of the sequences in the table below to indicate where the fault exists within the rear parking assist system. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes.
The Rear Parking Assist (RPA) Diagnostic Connector (UD7) is under the front of the center console behind the BCM - body control module.
SOURCE: Does not come out of Park, aid. Aux.Heater quit
there may be a switch on the brake lever which has malfunctioned... otherwise there is some safety switch connected to the gear lever which is hindering the operation..
Best regards
Ck
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
Testimonial: "Your solution worked. After I replaced the beeper, park aid system is working like new."
SOURCE: my 2002 buick rendezvous parking aid does beep
press the button its also an off and on switch
