Leisure cookmaster
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Testimonial: "That's great,confirmed what i was thinking.Thanks for your advice"
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
hope u find this useful. thank you.
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
