20 Most Recent
DeLonghi DEBIGE 2440 Electric Double Oven Questions & Answers
The fan works but oven does not heat up
If the fan is working o/k, and it it is an electric oven, then the oven element has probably failed.
It is usually located at the rear of the oven compartment behind a removeable cover.
Hopew this helps you.
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Delongi over nobs
yOU SHOULD NOT HAVE HEAT COMING FROM YOUR OVEN DOORS. MAKE SURE GASKETS ARE INTACT AND YOU OVENS ARE LEVEL.
Cooker
I just installed one in my house. I found that when you start the lower (gas) oven you need to turn the dial all the way on to 500*, push the knob in (you should hear the igniters clicking), then even when you see flames coming out of the burner, continue the ignition for 10 to 15 seconds. It should continue to stay lit thereafter.
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
