As per the previous response, use the recommended size of card - available from eBay and many other retailers. A general store is unlikely to have staff knowledgeable enough to help you.
? 2:22
https://www.youtube.com/watch?v=xVZUrKz2wSk
Oct 11, 2014 - Uploaded by furulevi
How to Format MicroSD card of SJ4000 sport camera. furulevi .... 64 128 GB MICRO SD CARD IN SJCAM ...
Apr 12, 2013 - When camera is turned on it says "please plug out card" What does that mean? ... put in a micro SD card and turned it on and it saying please plug out card what does that ... What does it mean if my camera says "card locked"?
Mar 2, 2014 - jazz JDC77 saying please plug card out means Just bought this ... SOURCE: I have a new Jazz DV151 camcorder and the memory card says full ... I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put ..
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
You can purchase an SD card any time you want, the DVX50 supports SDHC cards but will not support any card over 8GB. I suggest you take the camcorder to Best Buy so you can make sure you are getting the right SD card.
Try checking your manuel for specifically named memory card, sometimes certain cameras can only take certain memory card formats.
Hope this helps.
JD
I read the following spec for your camera:Recording Media
Internal Flash Memory 64MB Video/Image SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
An 8GB SD card will actually be a SDHC card, the HC means High Capacity. Your camera is only designed for regular SD cards up to a maximum capacity of 2GB; it's incompatible with SDHC at the basic hardware level and so cannot format the card.
You only have one solution: fit an SD card which does not exceed 2GB. Note that the specification for regular SD cards goes up to 4GB, but very few standard SD devices were ever designed or tested for compatibility with them. The few regular SD cameras which can use them mostly can only do so after a firmware update and even then will operate very slowly compared to when using a 2GB card. There has never been a firmware update to enable your camera to use 4GB SD cards.
I hope that you have found my posting to be of assistance and ask in return only that you return the favour by rating my answer.
