20 Most Recent
Jazz DV152 Camcorder Questions & Answers
Jazz dvx50 card locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
When I turn on my Jazz DV 152/ T20 it displays
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
I PUT A 4GB SDHC
push the card in with a pen or a butter knife or something skinny. then the card will release and pop out
When can I purchase a
You can purchase an SD card any time you want, the DVX50 supports SDHC cards but will not support any card over 8GB. I suggest you take the camcorder to Best Buy so you can make sure you are getting the right SD card.
My jazz dv152 keep on
I had the same problem. Check the SD card. There is a small slide button on the side of the SD card to lock or unlock it. On the Toshiba 2GB SD card the lock is yellow.
JAZZ DV152...I got the camera as a gift and it
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
How to turn camera on
You have to use 2 AA batteries on it ..and switch it on ...It has a switch for view pictures and one for shooting ...To make photos use the normal mode...it appears on the shooting mode....for videos ..press menu ..and select video mode..
The menu ..is explained in detail into the manual ...if you have it ....
for any setting s..choose setting feature from the main menu ..by highlighting ..and pressing ok ..
I cannot operate the camcorder
The memory card has a little switch on it. Lock and unlock. Make sure it is unlocked. If it is unlocked and you continue to have this problem, try a different brand card.
We cant get memory card to format so we cant use
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Need driver download for Jazz DV152
Well I have just been on the internet 10 min trying to find a driver for you and not one for that camera for any windows version, how old is the camera?
