20 Most Recent
Jazz HDV-188 Camcorder Questions & Answers
I need mac software for jazz HDV 188
According to the specs page on geeks.com (http://www.geeks.com/details.asp?invtid=HDV188-BP&cat=MP3), that camera supports Windows 2000/XP/Vista only.
I don't know what happened, I bought this camera
Many chargers will "cook" the battery if left in too long. Should be a thermal switch to stop charging when full and hot.
Also most batteries have a useful life of a couple years. If too dead wont charge. Come up with another way to power the camers
I HAVE A JAZZ ELITE
I found their contact information
jazz products llc
110 Ethel Road West, unit 2
Piscataway, NJ 08854
this is a address to contact them
www.jazzcameras.com is a website but no support there
Jazz hdv 178 : i have footage on sd memory card
The sd memory can be used with a usb card reader which can be connected to your computer then you can see it through Picture view that comes with windows. You can also transfer the pictures to the Hard disc and edit them.
How do I scan something from my printer (I put in a memory card) to go to my computer
Check "My Computer" / to see if it has shown up as a removable drive with its own clickable icon or title. Your printer drivers and control software should also have its own utility that pops up recognizing its existence. If not you can open your printer control software and search for it. If it is not there your drivers are probably an abbreviated version or you have upgraded to a later operating system and it is not supporting the ports.
What do i do?
I have a Samsung ace 3 mobile phone , I need to know how to put photos from other albums into just one ,I can download pics onto my computer but only from one album and each time i try to download its always the same photos abd I have several unamed albums,I am 78 yrs of age but I would like someone to tell me what to do as if i am a 4yr old in kindy,please try and help me.
Pam
Charging the Jazz HDV188...
I have the same camcorder but my problem is i cant get it to come on , Ive been had it on the charger its like its not charging can any one help me
I have a jazz hdv188 i just bought from a friend
according to the manual guide, you cannot use another recharging, only
the recharge that came with the camera, because you can get a problem on
the screen.
you have to use this ADAPTER>
Sunny* SWITCHING ADAPTER
MODEL: SYS1196-0605-W2
PART NO: SYS1196-0505-W2-C
INPUT: 100-240V-0.3A MAX 50-60Hz
OUTPUT: +5V_-_1.0A
OUTPUT POWER: 5W MAX.
Vivo en Argentina y la
Agrega una bateria nueva. Parece la que tiene no puede detener un cargo. quisa porque a durado mucho tiempo sin cargarla, se mojo, fue mal tratada, ya esta vieja, o la an cargado mucho. Los electronicos deberian ser desconectadas al momento que se llena el cargo. Si lo tienes conectado por mas tiempo le hase dano a la bateria. Hase que la vida de la bateria sea mas corta. Osea que no puede detener un cargo por el tiempo que deberia, y/o que no awante las recargadas que deberia. Como si deberia tener la capacidad te 300 recargadas nomas va a poder 200 o 100 depende en cuanto tiempo lo recargas despues que se llene la bateria.
Jazz camera bought from the
you should be able to charge the battery using a usb cable from your computer. see photo for type of usb cable you need. this cable should have come with the camera.
Hope this helps!
Tom
