Not sure if this link will help you find it but have a look.
user manual asko front loader washing machine W6011 Google Search
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
SOURCE: i have an asko quattro
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
