Televison & Video Logo
r
reynaldo Posted on Oct 25, 2017
Value r706-r705-r711-r710-r704? sharp M 21V-FX300S
1helpful
What is the value of r704 resistor on sharp slim tv 21v-fk220m
pa help naman po mga master..my rerepair po ako sharp tv..model21v-fk220m sira po ung regulator..strw-5453 sunod din po ung resistor na mlapit sa regulator..problem po d makilala ung resistor..anu po kya value nito meron po code na r704...slamat po sa sasagot godbless po..
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a · Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
1helpful
What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to many popular devices are given. You can fetch details there.
1helpful
Schematic diagrams of Sharp Color TV 21 Alexander Pro Model No. 21V-FX300S.
Check the IC numbers used in it kit; and distinguish which company kit is used with. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Burn r704 resistor in my sharp tv 21v-fr70m,, i want to know the value,,, help poh mga master...
leo_arsolaci.jpgleo_arsolaci,
sir here is the exact value of resistor r704-220 ohms and please check also the zener diode 8.2 volts....
I want to know the resistance value of r704 in my sharp 21v-fr7om.. it burn...
sir here is the exact value of resistor R704- 220 ohms and please check also the zener diode D732- 8.2 volts....
Alpine MRP 200 could you pls tell me valu of
I don't have a schematic for your deck however, if the resistors you need are not burnt beyond visibility, this PDF should be alot of help. http://www.electro-tech-online.com/electronic-theory/42899-resistor-colour-code-values-chart.html Hope this helps
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
