I have the same problem, does anyone know what is code of 7time blinking?
I don't have a service manual for that set so I'm only able to help on a limited basis...Have you tried the flashlight test?...if the backlights are out then it could be a backlight driver board if it has one? or defective LEDs. See what you have for voltage going into the panel LED's
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
SOURCE: 50PFP5332D/37 has sound and no picture.
try restting push the menu button in on the side for 5-6 second
SOURCE: If my Sharp Aquos 37in LC-40C37U tv needs to be
Blinking light is an error code. Count the blinks before they repeat. Check your manual in the troubleshooting section. If you can't find it, contact a Sharp service center or try and get a service manual. Reset info is also in the user manual but you can't do it if your set doesn't power up. Are you sure about the power board?
Testimonial: "Thank you. I will get another board."
SOURCE: Ok.... I got a new power supply board and the tv
The pattern of the blinking is a code. If the power light is blinking by itself once per second or thereabouts it could be loose connection to Inverters, reload firmware, Inverter Unit or LCD Panel.
Testimonial: "Thank you. I will let you know how it all works out."
Did you solved your problem? What was the solution to your TV problem?
