I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: Coby Kryos Android Tablet
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
