20 Most Recent Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM Questions & Answers
Coby mid8065
1. Turnn completly off the tablet. 2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen. 3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better. Regards! If that helped, don't forget to accept my answer!
9/6/2019 12:53:59 PM • Coby MID8065-8 -... • Answered on Sep 06, 2019
Hang
Turn OFF the device 2. Make sure its turned OFF 3. Press and hold simultaneously POWER + BACK + HOME buttons
7/9/2015 8:41:02 AM • Coby MID8065-8 -... • Answered on Jul 09, 2015
Why my coby mid8065 stop working i try the reset button but still nothing happen, it show the coby logo and the android but didn't go far.
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
9/8/2014 9:04:53 AM • Coby MID8065-8 -... • Answered on Sep 08, 2014
How to root
hmm you need to delete some things 1st or add more memory ...
3/29/2014 5:22:52 AM • Coby MID8065-8 -... • Answered on Mar 29, 2014
0answers
0answers
0answers
I can not turn the tablet on by reset after instructed.
hi check battery pack
1/26/2018 9:16:45 AM • Coby kyros... • Answered on Jan 26, 2018
How do I factory reset my Coby Kyros 1125?
  1. Hold down the Power button for a short while to turn on the device.
  2. Go the Menu and find and select Settings.
  3. Choose Backup & Reset
  4. Select Factory data reset
  5. Select Reset device
  6. Select Erase everything
10/17/2017 11:00:49 AM • Coby kyros... • Answered on Oct 17, 2017
2answers
Factory reset for coby MID7030
Hi Hisham, I have this site for you on how to reset your device. It includes image as well. Hope it helps. Hard Reset Procedure For Coby Kyros mid 7030 4
5/19/2016 4:38:46 AM • Coby kyros... • Answered on May 19, 2016
Coby MID8065-8 - Kyros MID8065 8 8 GB Tablet - Wi-Fi - ARM Logo
15 questions posted
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
kyros Coby
  • kyros Coby
Most Popular Question
coby mid8065 stop working try reset
  • Tablets & eReaders
