20 Most Recent
Coby Kyros 7" Touchscreen Tablet Questions & Answers
Download manual
Hope this is your model: http://www.manualslib.com/manual/254203/Coby-Kyros-Mid7015-4g.html
The charger broke off of my coby kyros tablet
You'll have to send it back plus $15.00 for shipping & handling,the company is something to deal with. My tablet still has not been replaced and I sent it back Dec.3 2012,they've received it too!! They are a mess!!
My Coby Kyros mid 7048 is frozen on android? How do you fix that problem?
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Help
Most Tablets gets reset with this procedure.
If it is not self recovering after powerdown, you have to reset to factory settings (meas you will losse your apps) to do do this most tablets gets reseted by presing both (Up-Down) volume keys before pressing the power on button. A text menu will appear asking you the action, you have to choose Factory Settings. Your Tablet must be poer off before to perform the avobe procedure. Hope it helps...
If not volume keys works try other tablet keys. but always press keys convinations before the power on key.
I made a really hard password for my tablet and I can't get in.
Hi Elena, you can use the following procedure to hard reset your tablet.
Turn off the tablet. Hold the back button and power button. This will take you into the recovery menu, use the volume keys to go through the menus. Select wipe data/factory reset and press the back button.
I hope this helps.
I need to reset my tablet
Hi Elena, you can follow this procedure to reset your tablet.
I hope this helps.
