Coffee Makers & Espresso Machines Logo
Kip Venn Posted on Sep 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Leaking delonghi nespresso coffee machine
  • Roger Laine Dec 12, 2018
    Excellent. Problem solved immediately!
kim atchison
Level 2:
Habit-Forming:
New Friend:
  • Expert 65 Answers
  • Posted on Sep 21, 2017
kim atchison
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
65
Questions
0
Helped
17234
Points
299
5 Related Answers
Anonymous
  • Posted on Dec 05, 2009
SOURCE: coffee not hot enough
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Anonymous
  • 1970 Answers
  • Posted on Jun 20, 2010
SOURCE: i need a manual for my delonghi cafe parma machine
mcdevito75 here, You may be able to get the manual online at Delonghi Caffe espresso machine.
Anonymous
  • Posted on Sep 05, 2010
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Anonymous
  • Posted on Aug 07, 2012
SOURCE: My Delonghi N95 Nespresso machine
Our machine leaks water when making a coffee. I removed the left sue panel to find there is a silver metal cylinder thing in the back that has heavy corrosion on the bottom. I would say it holds the heating element. Disappointing to see that much corrosion inside like that.
lenmulaski
lenmulaski
  • 44 Answers
  • Posted on Aug 28, 2012
SOURCE: User Manual
Here you go...good luck! :) http://kitchen.manualsonline.com/manuals/mfg/nespresso/c290_d290.html
3answers
Just recd a Nespresso DeLonghi coffee maker. Put in a capsule to make my first coffee and it didn't produce a coffee. The lever won't open. I have unplugged the machine. Not sure what to do?
You are not the first person to encounter such a problem. I recommend to read specialized articles with tips from the masters of service centers. Here you will find a way to repair your coffee machine yourself.
http://33coffeemakers.com/nespresso-coffee-maker-troubleshooting/
The milk is not heating up in my Nespresso Delonghi, can you please help Sharon
Good morning Sharon,by now your problem may have been solved., hope so. Take look at this
http://www.manualsonline/ and see if it helps.
enjoy your coffee,
Kolbrun
Does anyone know how to pull apart a Nespresso coffee maker ?
Most expresso coffee makers can be taken apart manually.
Start removing screws, nuts, etc. Take a picture every so often so you know how to put it back together.
See the DeLonghi website to get eerie product manuals. (delonghi.com). Search harder for repair parts and you often can get the sequence of how the parts assemble.
You are right, cleaning the jets is the biggest problem area.
2answers
My Delonghi N95 Nespresso machine is leaking water
on a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Ant
Is there a dutch manual for the Delonghi EN 680?
Try the manufacturers web site. They should have the manual in different languages. If not, try a search engine like google and type in "manual for Delonghi EN 680 in Dutch"
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
