I have no reset hole on this unit. What next? Need Help.
SOURCE: 2001 Hyundai elantra. Headlights, electric
check for any circuit brakers near the fuse box, if theres any of them reset them by introducing a paperclip in the small hole and press, you will hear a click.
SOURCE: 2003 hyundai elantra gls abs/tcs light on
unless you can discover what DTC (Diagnostic Trouble Code) has been recorded/set in the control module, it's anyone's guess.
Testimonial: "thankyou"
SOURCE: 2002 hyundai elantra radio and dome light not working
Then 1, bulbs are burned out
OR 2, the wiring is faulty.
Testimonial: "thanx for the solution. took the car to a repair shop and was told that the wiring was faulty. had the car rewired."
SOURCE: XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
SOURCE: 2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
