Electrical Supplies Logo
M
MEHMOOD QAISER Posted on Sep 04, 2017
I NEED STANDARD WIRING DIAGRAM FOR LEVITON ROTARY DIMMER SWITCH MODEL 6683 220 V0LTS
5 Related Answers
Anonymous
  • Posted on May 05, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Anonymous
  • 44 Answers
  • Posted on May 30, 2009
SOURCE: newly installed Leviton dimmer switch humming at the switch
You'll need to install an electronic dimmer, like a Maestro. Otherwise, you'll have to live with the hum.
Anonymous
  • 22 Answers
  • Posted on Jul 24, 2009
SOURCE: replace dimmer switch with toggle
Both wires should be black because the switch interrupts or breaks the connection to the light. It doesn't matter which black wire goes where. Just be sure the power is OFF and then undo the dimmer switch (usually has wire nuts connecting the black leads) and then connect the wires to the new toggle switch.
Turn on the power and feel good about your work!
Anonymous
  • 4090 Answers
  • Posted on Jul 27, 2009
SOURCE: I want to replace dimmer switch with standard switch
the two black wires spliced are Live wires ( same value as RED) the other single black is the return. The two twisted blacks from the wall go into ther active hole of the new switch and the single into the return. No third wire for earth is needed
Anonymous
  • Posted on Aug 09, 2009
SOURCE: I have a leviton 057 with 2 black wires and 1
house has a black and a white line and a ground commper, dimmer has two black and a green
How do I know which blck lead goes to white and which goes to black? One lead is shorter than the other.
I'M REPLACING AN OLD LEVITON ROTARY DIMMER WITH A LUTRON PADDLE DIMMER. THIS IS A 3-WAY SWITCH. THE ROTARY DIMMER HAS 2 BLACK WIRES, 1 RED, AND 1 GREEN. THE NEW DIMMER HAS 1 BLACK WIRE, 1 RED, 1...
with a three way switch like this, you will have two traveller wires and a common wire. Look in the instructions for the switch or on the back of the device itself to see if there is a wire labeled "common" or "com". This common wire from the old switch hooks up to the common wire on the new switch. I did a bit of searching on the leviton 6602, but couldn't find anything specifically about the three way version (I would venture to guess, however, that the red wire on the old switch is the common). The common on one of the three way switches will always be a constant hot (or power) wire...the common on the other three way switch will be the "switch leg" or the wire that connects directly to the light. The two travellers go to the other two wires. Check the pamplet that came with the lutron device, it should show which wire is common and which are travellers.
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
1helpful
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
I have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
2helpful
I have a trimatron rotary dimer and i have no clue how to replace it with my other switch. the problem is the other switch only uses 1 black and 1 red wire not 2 black and 1 red plzzz help
If the dimmer has two leads, it is a standard dimmer. One wire brings power into the dimmer, the other lead send "dimmed" power out.
If the dimmer has three leads, it is a 3-way, which is a combination of a dimmer and a 3-way switch. One wire brings power into the dimmer, and the other two leads bring "dimmed" power out - when you cycle the on-off function (by clicking the switch) you are sending the "dimmed" power out one lead or the other. You can use a 3-way dimmer in place of a standard 2-way by simply not using one of the 2 wires coming out of the switch. BUT you must be certain to insulate the end of the lead you aren't using, because when the switch is "OFF", this unused lead will be live. If you are actually trying to wire a 3-way, here's an excellent how-to-- http://www.ehow.com/how_2280970_wire-threeway-dimmer-switch.html Please vote if you found this helpful. Thanks, Al
3helpful
2answers
Leviton 057 dimmer 2 black and 1 green wire in a
i want two dimmer switch parrel they both fhave two black and one green how fo you wire it up
1helpful
2answers
Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
