20 Most Recent Leviton #L11-06681-00I Ivory 600 Watt Push On/Off Dimmer Switch Questions & Answers
The dimmer switch will turn
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
10/31/2010 11:13:38 PM • Leviton... • Answered on Oct 31, 2010
How do I connect a Leviton 6230M in line with a humidistat controller ... so any one of these sources will activate bathroom exhaust fan 120v ac
You parallel the contacts then either one or both will turn it on. Both have to be off for the fan to stop.
10/2/2021 3:00:18 AM • Leviton... • Answered on Oct 02, 2021
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM • Leviton... • Answered on Jul 05, 2021
2answers
Thought I wired leviton 5224 correctly, but looks like switch for fan is ok, but the only time light switch works is when fan runs also, so must keep light always on. What can be wrong?
It's two single pole switches with a removable jumper on one side. With jumper intact, you connect the hot feed to a either screw of the jumper which I belive are brass colored screws.
Then the two induvidual switch poles are the silver screws. Connect fan motor to one and fan light to the other.
If that doesnt work for you, take a picture of the switch and connections and another of wires in fan box and post here.
4/9/2020 8:04:38 PM • Leviton... • Answered on Apr 09, 2020
My Leviton VPT24 Outside light switch went totally blank. The light do not turn on. Is there an internal battery?
https://www.leviton.com/sites/REST/controller/LCDownloadController/download/DI-000-VPT24-02F-W.pdf?docurl=/en/docs/DI-000-VPT24-02F-W.pdf Yes, but appears to be non-serviceable... and its probably just a 3.2vdc lithium coin battery inside the case yet they decided to make it so you have to buy a replacement every 10+yrs. Crack it open and see (dill off any rivet heads).
2/18/2019 11:23:31 PM • Leviton... • Answered on Feb 18, 2019
Does a leviton slide dimmer switch use regular bulb's
what do you know as "regular " bulbs are they low energy or incandescent
10/11/2018 5:50:39 AM • Leviton... • Answered on Oct 11, 2018
Dimmer slide does not dim
Replace it. They fail and and that is not uncommon. good luck
5/20/2018 4:04:38 PM • Leviton... • Answered on May 20, 2018
2answers
I have an old easyset E-600VA dimmer connected on single pole to a ceiling light. I want to replace that with a new Leviton toggle switch with dimming slide.
red never connects to black as that is power to neutral if wired correctly get in a qualified electrician to check the wiring and help you install the unit
5/1/2018 11:36:21 AM • Leviton... • Answered on May 01, 2018
How can I wire 3 Lutron Dimmer switches in a series? Each switch will control a different set of lights. I pig tailed the black power source to each of the dimmers. I ran the black wire from the l
yes, take the white wires off the switches and splice them all together with a wire nut. Run a hot wire to each of the switches and then run the switch leg (black) from each of the fixtures to be controlled to each of the dimmers.
12/18/2017 3:05:53 AM • Leviton... • Answered on Dec 18, 2017
I am trying to wire a Leviton 3 rocker/4 function switch to a fan with fan/heat/light/night lt. There are 3 colored wires out of the back red,black,blue and 2 load screws.
If the two load screws are connected with a tab that is the power in side. The color wires are the load.
11/3/2017 1:27:47 AM • Leviton... • Answered on Nov 03, 2017
I have had several failures of the Leviton Decora
Seems to be a common problem, you're not alone ( read amazon 1 star reviews). They are $22.00 so you will to dispose of it, if Leviton will not warranty it.
10/27/2017 12:20:51 AM • Leviton... • Answered on Oct 27, 2017
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
5/1/2017 3:42:09 AM • Leviton... • Answered on May 01, 2017
I have a bedroom switch controlling a ceiling fan (separate speed switch) and a wall switch going to an outlet. I can't get the outlet to work with the wall switch. The fan works fine
You need to verify if there are two wires coming to the wall switch from the receptacle. One should be power in, the other should be power out to the receptacle.
5/1/2017 3:36:47 AM • Leviton... • Answered on May 01, 2017
Wire occupancy sensor to control receptacle
Your description doesn't explain the circuit, the function of the wires or how the switch controls the outlet and whether the switch is a single pole or two-pole switch. Without such details it is difficult to visualise the circuit. I advise before you go further to test the sensor in a known good and correctly wired outlet using a length of cable and a suitable plug for the outlet. It is possible the unit is faulty. If it functions correctly on test you will need to understand the circuit and the function of the wires before you rewire it to assure success.
4/18/2016 2:23:52 AM • Leviton... • Answered on Apr 18, 2016
How do you wire a switch at the end of two lights wired in paralell?
You MUST to interrupt the circuit between the the power source and the lamps. The switch is in series with the lamps that are in parallel as shown below: 25955740-5h2dbzfnzltxrngjp2sobitb-5-0.png
11/12/2015 9:16:55 PM • Leviton... • Answered on Nov 12, 2015
Leviton #L11-06681-00I Ivory 600 Watt Push On/Off Dimmer Switch Logo
Popular Tags
1 questions posted
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Leviton Electrical Supplies
Most Popular Question
  • Electrical Supplies
