Turn off the timer in menu set
Good morning everyone I've been having a problem with my jvc Tv. I noticed that sometimes when using an app that has been downloaded to tv causes the timer to pop up with a one minute count down then shut down by itself. I turned of the osd and sleep timer, but no difference whenever an app is open and in use that's the time the one minute pop come on..
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
