Unhook all your connections to the head unit except for the red 12v b+, yellow which is 12v for memory, and black which is ground. What this does is check to see if it's something connected or if the unit itself has a problem internally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
SOURCE: Kenwood kdc-mp"635"------ protect "help"
I have a kenwood kdc-mp635 and when i turn on my radio it reads protect...i recently bought it a month ago and it was all fine till a couple of days ago i was driving and it turned off and said "protect"! i reseted it and it worked for like literlly a minute then back into protect mode.. i check all my wires, amps, grouds, cdplayer wiring and cant seem to find the problem... before when i reseted it, it worked for a minute then went into protect....now it doesnt even turn on anymore all it does is reads "protect" i reseted it and still nothing....it doesnt turn on after i checked all my wiring and grouds...im stuck and in-need of help..i have no musicccc.....no radioooo...!!! i dont know what else to do?????
SOURCE: wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
SOURCE: geo prizm stereo radio wiring diagram
1994 Geo Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: White/Black
Car Radio Illumination Wire: Red/Yellow
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): White/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Light Green/Black
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Gray/Black
SOURCE: special wiring harness for new stereo in 2005 sierra
Yes u do....I have an 03 sierra and apparently they changed everything in 03.....the harness is over $100.....but u need it....and they dont sell a reg wiring kit from 03 and up....if it was an 02, then yes u could get away cheap......it has to do with the steering wheel switches
